Can "Footswitch Sequencer" take a Trigger Out from a drum machine?
Hello,
Can the "Footswitch Sequencer" input take a Trigger Out from a drum machine, in my case, a Roland TR-8S, to run the sequencer?
What is the voltage range (as an audio signal) to trigger the sequencer step?  Is there any danger I might send a signal that is too hot and damage the Prophet 6?
Thanks,
Steve
Re: Can "Footswitch Sequencer" take a Trigger Out from a drum machine?
« Reply #1 on: June 23, 2021, 12:39:35 PM »
I'll answer my own question as i have now found out.
Yes, you can.  You need to ensure Global 2 - 1 is set to "TRI" rather than "NOR".
Thanks,
Steve
