New Sequential Patent - Take 5
« on: June 01, 2021, 06:30:41 AM »
Saw this earlier on GS
https://uspto.report/TM/90726508
jok3r
  • 342
Re: New Sequential Patent - Take 5
« Reply #1 on: June 01, 2021, 06:37:44 AM »
I do not even have a guess what a "Take 5" could be...
  • 1543
« Reply #2 on: June 01, 2021, 07:45:45 AM »
Possibly a looper/sequencer, at least thats the first thing that jumped into my mind.
  • 1812
« Reply #3 on: June 01, 2021, 08:08:22 AM »
Now I'm disappointed that Talkin Ball never came to fruition
https://uspto.report/TM/88374998
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
« Reply #4 on: June 01, 2021, 11:01:31 AM »
Obviously the long awaited multitimbral kazoo featuring a 5 step sequencer.
« Reply #5 on: June 01, 2021, 11:25:42 AM »
Seriously hope it's a dedicated sequencer.
But Dave said the next two instruments will be Analog so....I have no idea how that would work.
Surly it wouldn't be an analog synth called the Take 5.....unless it's a 5 part multitimbral monster synth.
In either case it best have a picture of Dave Brubeck on the front panel.
« Reply #6 on: June 01, 2021, 11:37:08 AM »
Now that's just inaccurate, Paul.  It's not the kazoo that is multitimbral, but the fact that you can fit several different models in your mouth all at once, thus producing a broad and varied sonic range of layered kazoo richness.
« Last Edit: June 01, 2021, 12:52:03 PM by Sacred Synthesis »
« Reply #7 on: June 01, 2021, 12:03:19 PM »
It's the REV 5 called the Prophet 5 REV 5 TAKE 5.
« Reply #8 on: June 01, 2021, 12:35:35 PM »
a broad sonic range of layered kazoo richness
I like the sound of that.
« Reply #9 on: June 02, 2021, 09:17:43 AM »
Well, I mean PEK was only 4 voice.  I eventually added a 5th voice via polychain which made it more useable.   But yes, in this day and age just 5 voice poly would seem unlikely.
« Reply #10 on: June 02, 2021, 09:59:59 AM »
Unless it's 5 part multitimbral. That was my suggestion for a "Pro 4" idea. Essentially 4 AS-1 mono synths that can each have it's own sound, sequence, effect etc.
« Reply #11 on: June 08, 2021, 11:38:19 PM »
How about this? Perhaps it’s a 5-vector morphing synth.
X-Y plane has four parts; if you add the Z axis, that gives 5. Perhaps with a controller similar to the Polybrute’s Morphée to access all five parts (as opposed to the 4-way joystick of the Prophet VS).
« Reply #12 on: June 09, 2021, 05:13:51 AM »
Possible. Paul Dither made a design with a touch pad once.
« Last Edit: June 09, 2021, 05:18:10 AM by LoboLives »
« Reply #13 on: July 02, 2021, 02:23:08 PM »
Hmmm ... something to do with Dave Brubeck and rhythm ...
Sounds like a new drum machine to me.
5 different synthesis type? Subtractive + Wavetable + Physical Modelling + FM + Sample?
Or some new modal synthesis technology (modal synthesis ~ modal jazz)?
Just my speculation  :P
« Last Edit: July 02, 2021, 02:30:04 PM by Wavtekt »
« Reply #14 on: July 03, 2021, 06:52:09 AM »
Dave said the next two instruments are analog....so unless they are going to do a completely analog drum machine (which I think would be a misstep as I think everyone has moved on to different forms of synthesis) I can't see it happening.
Roger Linn also said he thinks Dave is done with dabbling in drum machines because of the fiasco with the Tempest.
But I wouldn't be opposed to the idea of a 5 different forms of synthesis in a drum machine, I just hope that it has multiple midi channel outputs.
Dave once teased the idea of the Prophet X sample technology being put into a drum machine but Pym said it would be an absolute nightmare to implement in terms of multitimbrality.
« Reply #15 on: August 20, 2021, 08:21:41 AM »
Info from Abtmusic & Dutch Synthforum:
https://www.synthforum.nl/threads/3808999/
https://www.abtmusic.eu/sequential-take-5-synth/
Take 5 specs :
OSCILLATORS
Two analog VCOs per voice
Continuously variable wave shape (sine, sawtooth, variable-width pulse) per oscillator
Hard sync: oscillator 1 syncs to oscillator 2
Square wave sub-octave generator (oscillator 1) per voice
Keyboard tracking on/off for each oscillator
Front-panel FM (frequency modulation)
MIXER
Oscillator 1 amount
Oscillator 1 sub-octave amount
Oscillator 2 amount
White noise amount
LOW-PASS FILTER
Four-pole, resonant, analog low-pass filter per voice, based on Prophet 5 Rev 4 design
Filter can be driven into self-oscillation with the Resonance control
Bi-polar filter envelope amount
ENVELOPES
Two 5-stage envelope generators (ADSR + delay) with variable routing (filter, amplifier, gate)
Velocity modulation of each envelope amount
Envelopes freely assignable to multiple modulation destinations
LOW FREQUENCY OSCILLATOR
Five wave shapes: triangle, sawtooth, reverse sawtooth, square, and random (sample and hold)
Clock sync (internal or external MIDI clock)
Freely assignable to multiple modulation destinations
DIGITAL EFFECTS
One dedicated reverb with damping, pre-delay, decay and tone
One multi-effect with stereo delay, BBD Delay, tape delay, chorus, flanger, phaser, ring mod, vintage rotating speaker, distortion, high-pass filter
Dedicated Overdrive effect
VINTAGE KNOB
Recreates the characteristics of vintage synthesizers by introducing micro-fluctuations in oscillators, filter, and envelopes per voice.
AFTERTOUCH
Source: channel (mono) aftertouch with bi-polar amount
Aftertouch freely assignable to multiple modulation destinations
CLOCK
Master clock with tap tempo
BPM control and display
MIDI clock sync
ARPEGGIATOR
Up, down, up+down, random, assign modes
Syncs to MIDI clock
Re-latching arpeggiation
SEQUENCER
Polyphonic step sequencer with up to 64 steps with ties and rests
PERFORMANCE CONTROLS
Full-sized, semi-weighted, 3.5-octave premium Fatar keyboard with velocity and aftertouch
Spring-loaded pitch wheel with selectable range per program with independently adjustable upper and lower pitch wheel range transpose controls
Low-split mode creates two independent performance zones with different octave ranges
Hold switch latches held notes on
Polyphonic glide (portamento)
Unison (monophonic) mode with configurable voice count, from one to all five voices, and key modes
Factory switch: when off, the front panel is live; what you see is what you hear
PATCH MEMORY
128 user and 128 factory
IN/OUT
1 MIDI In, 1 MIDI Out, and 1 MIDI Thru port
USB port for bidirectional MIDI communication
1 Sustain/footswitch input
1 Expression pedal input
Main stereo output (2 x 1/4″ phone jack)
Headphone out (stereo 1/4″ phone jack)
POWER
IEC AC power inlet for internal power supply
Operates worldwide on voltages between 100 and 240 volts at 50 to 60 Hz; 14 watts maximum power consumption
PHYSICAL SPECS
Premium, 3.5-octave, semi-weighted Fatar keyboard
25″ L x 12.75″ W x 4.4″ H (63.5 cm x 32.4 cm x 11.2 cm)
Weight: 17 lbs (7.7 kg)
« Reply #16 on: August 20, 2021, 08:54:23 AM »
But....
Why?
« Reply #17 on: August 20, 2021, 09:36:45 AM »
So it's a Prophet 6....but with one less voice and half an octave missing. Mmkay.
I do appreciate the idea of a lower tier analog poly synth from Sequential. I've been pushing for a MophoX4 successor....maybe this is it?
« Reply #18 on: August 20, 2021, 10:28:22 AM »
You know.....on second thought, I understand it. It's more a successor to the MophoX4 than a Poly Pro 3 or modern Prophet 5 or whatever. It's a stripped down, basic, lower tier analog poly synth.  It's more for people who are primarily playing another instrument and just want a basic analog poly synth next to them to play a few chords. Nothing elaborate or expensive.
« Reply #19 on: August 20, 2021, 11:36:49 AM »
Specs say ”based on the P5 filter”; I wonder if it’ll have a resonance compensation option.
