The
fastest way to do something like this is with Serum and WAV2Pro3:
https://www.youtube.com/watch?v=GV-S54zcGiYThe usual objection is that Serum is expensive. But it's about as expensive as other plug-ins, and it's far and away the best way to make Pro 3 wavetables.
I've posted a wavetable with the first 16 waveforms of Piston Honda's first factory set:
http://www.wav2pro3.com/?715bba2f5745812e7b8a38842dae66bbYou can also upload these wavesets
directly to WAV2Pro3, without using Serum, if you select 256 as the Frame Size. There are two downsides to this:
(1) WAV2Pro3 will downsize the PH's 64-waveform table to 16 waveforms by discarding 75% of the waveforms at regular intervals (that is, you'll get 1, 5, 9, etc.)
(2) Two of the factory WAV files (#1 and #3) are malformed (the data header lies about the file size). So WAV2Pro3 can't transcribe them properly without modification in, say, Audacity. Simply opening them and re-saving should do the trick.
Anyway... The wavetable oscillator is one of the most fun things about the Pro 3, and Serum is an excellent companion for getting the most out of it.
