OS 1.5.2 Bug Report List
Re: OS 1.5.2 Bug Report List
« Reply #20 on: July 04, 2021, 09:50:27 AM »
Did you "Calibrate the oscillators and filters" as per page 5 in the Manual ?
Does the temperature in your room fluctuate much ?  Air conditioner ?
The room is at a constant 70 degrees. I do calibrate it as per page 5, as it is usually slightly out of tune overall after it warms up. Then after playing a while, usually after switching patches, a couple of voices will go out of tune like they lost the calibration settings. By out of tune, I mean very out of tune, almost not tracking the keyboard, while the majority of the voices stay perfectly in tune. I know this because unison patches are in tune unless unison is 8 or more. In poly mode most voices are in tune with a couple of notes playing massively out of tune. Re calibrating by pressing tune fixes the problem. It can’t be my unit. As I stated, all 3 units I have had did exactly the same thing. All 3 had 1.5.0 when I received them which I used for a few days with no problems. All 3 after updating to 1.5.2 started doing this right away. The unit I have now is a new out of box unit. I had a previous new out of box unit which was returned due to a malfunctioning led in one of the filter switches, but was otherwise fine. The second unit was a floor model which was fine. All 3 behaved the same.
« Reply #21 on: July 04, 2021, 11:55:18 AM »
Thatīs strange .....   Does turning "Vintage" knob to 4 anything to sound better ?
If itīs a 1.5.2 OS bug some more users would report about it .  I guess ....    : /
OS 1.5.2. downloaded 326 times at this moment ......
Mine P-10 with OS 1.5.2. has no tuning issues  ( knock on wood ....  )
 Cheers !
1976 MiniKORG700s // 1978 Prophet-5 rev.2 // 1981 KORG CX-3 // 1984 DX7 // 2020 Prophet-10 rev.4 // MoPho Box // 2 Creamware MiniMax // Creamware Pro-12 // 2 EMU-Proteus 2000 // EMU-Vintage Keys  // Casio VZ-10M // Roland VK-8M // Fatar SL 880 //
« Reply #22 on: July 05, 2021, 10:08:14 AM »
 Cheers !
By the way OS 1.5.2 also can be downloaded from the support website. Not only from here.
My P10 is working flawlessly.
Micky
« Reply #23 on: July 17, 2021, 12:24:35 AM »
No calibration possible .....   ???
Tried different pedals .....  :P   Same stepping in filter cutoff ....   >:(
Smooth filter with front panel knob, no stepping ....   :D
Se this tread for more on the subject :
https://forum.sequential.com/index.php?topic=5040.0
Cheers !
Like i wrote in the other thread...
Using the P10-cutoff-knob everything is o.k.
Using the P 10 -Pedal to trigger the cutoff of my OB6 or P6 everything is also o.k.
Because of this i think, it has to be possible to fix that issue and please, not so far...
« Reply #24 on: July 17, 2021, 02:32:20 AM »
Cheers !
Been in contact with support about this, and itīs "in the bug fix pipeline" so to speak ....
Lets hope 4 the best that itīs solved in next OS upgrade   :)
Cheers !
