tips for sound like pizzicato P12
« on: May 30, 2016, 01:13:50 PM »
hello friends, do u have any tips for Pizzicato sound ?
Re: tips for sound like pizzicato P12
« Reply #1 on: May 31, 2016, 09:22:30 AM »
For a pluck type sound you need to set the Amp Envelope sustain to 0.
Then adjust the decay to give you the length of the plucked note, use a modulation slot with VCA Env as source and Amp Env Decay as destination, adjust the Amount up to give the type of decay curve you are after, you will also need to adjust the Decay time as you do.
The amp release setting is used to set the decay after you release the note, set low for a mute effect, set the same as the decay (including modulation slot) for note release not affecting the length of the played sound.
You can also do the same sort of thing using the LPF which can produce nice plucked type sounds.
« Reply #2 on: May 31, 2016, 09:48:13 AM »
 :) I 'm gonna try this, thank you very much.
Alex, from Paris
« Reply #3 on: May 31, 2016, 10:52:52 AM »
No problem.
Let me know how it goes.
