Pro2 cv in
Pro2 cv in
« on: October 04, 2015, 08:19:43 AM »
I have been trying to control my pro 2 via cv in from my analog four ( elektron ) but i can't seem to have it work with Volt per octave, only gate and trig work... Can anyone help me? Do i have to setup the pro2 a certain way to received the cv in volt/oct?
Thanks for your help!
Re: Pro2 cv in
« Reply #1 on: October 04, 2015, 08:52:28 AM »
You need to use the mod matrix.
For instance if you have CV C from the A4 (setup as V/Oct) connected to CV 2 of the Pro 2. Add the following modulation slot
Source  = CV Input 2
Amount = 64
Dest      = Osc All Freq
You will need to mess around with the tuning on the A4 CV page and also maybe with the CV 2 In Scale on the Pro 2.
« Last Edit: October 04, 2015, 09:02:44 AM by BobTheDog »
Re: Pro2 cv in
« Reply #2 on: October 04, 2015, 01:02:31 PM »
I had tried something similar before but it did not work… how do you come up with an amount of 64?
Re: Pro2 cv in
« Reply #3 on: October 04, 2015, 01:31:28 PM »
Well originally I thought it was 127, then I tried it and 64 seemed to give 1V/Oct.
I had this working earlier with my A4 and the pro 2 using those settings. The tuning was slightly out over a few octaves so some playing about with the CV in scale on the Pro 2 is required to get it spot on but I didn't have the time to perfect it.
Re: Pro2 cv in
« Reply #4 on: October 05, 2015, 07:35:40 AM »
Super! Thanks for your help.
