What bank and program number is this? Also, If the A/B Stack button to the left of the screen is lit, then the program is using a two-layer patch. So, when you shorten the Release time, only Layer A is being affected. To affect both layers simultaneously, hold down the Edit Layer B button. When it begins to flash, you're able to affect both A and B layers simultaneously whenever you turn a parameter.
