Hold not working with the arpeggiator
greg smith
« on: March 31, 2021, 01:05:17 AM »
OS.1.1.5.9
Hello All,
Is there any reason that the hold function would not work with the arpeggiator?
I have a basic program, sync set to off. Hold works with arp off, but with the arp on, the hold button lights up,
but doesn't hold - instead all notes are cut and silence ensues.
The manual says it's supposed to work and I've tried all the global/misc parameters that I though might cause this behaviour but I can't fix the problem.
Greg
timboréale
  • 206
  • MIDI nerd
Re: Hold not working with the arpeggiator
« Reply #1 on: March 31, 2021, 06:10:28 AM »
If you have the system set up to require MIDI clock the Arp doesn't run unless the board is getting active clock right then. Are you sending it clock?
greg smith
« Reply #2 on: March 31, 2021, 07:49:14 AM »
No MIDI clock mode is set to 'off'
