Tempest - sustaining note issue.
« on: March 27, 2021, 03:05:37 AM »
Have any of you experienced a similar problem? After a while, one long sustained, often looped note remains. I press the stop and the sound keeps on playing. The only solution is to turn the Tempest off and on. It sounds like a synth - not a drum sound. Do any of you know where it comes from and is there any trigger that may trigger it?
Re: Tempest - sustaining note issue.
« Reply #1 on: March 27, 2021, 06:10:47 AM »
Is it happening in all of your sounds?
Check your Peak Amp or any envelope assigned to amp level..If it’s been set to the max it creates drones...
« Last Edit: March 27, 2021, 06:13:26 AM by Yorgos Arabatzis »
« Reply #2 on: March 28, 2021, 01:13:40 PM »
I've had this kind of glitch before but only very rarely. It's like the voice os locks up or something.
« Reply #3 on: Yesterday at 02:23:51 PM »
I am experiencing the same issue, originally thought it was a midi loop. It occurs in the higher range of notes. Anybody know if this is a thing, how to fix or work around?
« Reply #4 on: Yesterday at 06:28:42 PM »
Factory reset and voice calibration seemed to do the trick.
