I have an Eventide Space pedal that is connected to the PRO 2 midi out, so that when I select a patch on the PRO 2, the proper preset is selected on the Space. I need the external midi clock to also reach the Space; right now the only way I've tried that works is to merge the external clock with the PRO 2 output using a Midi Solutions merge box, which works fine for this, but I'd like to simplify my setup if possible.
Is there any way to merge these in the PRO 2 itself, so that the external clock and the PRO 2 midi out both reach the Space? I've tried all the global settings with no success. I thought that the "slave thru" global setting would work for this, but it does not.
My other workaround would be to use my new MidiHub to create the merge, which I have not tried yet (but should do the trick, I think).
