Lets just say, that it will be more complicated than most would think...
Many companies these days have begun using just NRPNs for parameter changes... DSI do not give you any SysEx structure descriptions anymore, simply because all controllers try to only take on NRPN or CC for parameter changes, and basicaly that is all you need to edit all parameters... the device only need to maybe scale the NRPN/CC value.
But this is only good for one way communication in most cases, and never lets you get at the memory locations... this is where SysEx is needed every single time.
The problem is, that if it is to be capable of handling SysEx, it gets complicated, as SysEx allow for basicaly anything the manufacturer decides... there are no rules, no specific protocol for how to represent the parameters... some use bytes, some use words, and again, others use totaly different approaches... also how the parameter values are used are varied... many digital synths with FX, usualy have a parameter (a byte in the structure) that will be used differently depending on what FX type you have selected... so a universal editor should be capable of differenciating on one byte, depending on what another byte is, to fascilitate this, and also be capable of showing different parameters on the screen, depending on what FX has been chosen etc...
Then there is the checksum nightmare... you have to account for any god damned type available, and all those not yet thought up.
Yes... it can be done, but if you thik it will be easy to setup an editor without knowledge of bits, bytes and what have you, I think you'll be disappointed. especialy if you want to be able to include all past synths end devices out there.
On the other hand, if you made a COMPLETELY specified protocol for SysEx, that EVERY synth manufacturer adhered to from now on, then it shoudl most definitely be possible, and not even that complicated... but you will eventualy run into the problem, that at some point, someone will find the protocol unsatisfying, and they will add on it, change something and then things start to get out of hand again.
Another aspect you have to consider is, that even if a common protocol were made, then what the parameters represent will always change... you could have a simple ADSR envelope graphic representation ... but then what about the Blofelds multistage envelopes?... that would also have to be custom accounted for... even if you could make one that would catch almost all types of multistage envelopes, at some point, someone will come up with an envelope it cannot hande in it's graphical representation.... same goes for other graphical representations... wavetable editors? ... some have 64 bytes, some 128... future ones may have more, you do not know what will come, and thus the protocal and interface would have to be constantly updated with new support.
It's a daunting task... just look at how comprehensive the custom editor is in the old SoundDiver application... before you know of it, a universal editor will be so complicated to create for, that you'll have to have some kind of programing eperience... many times so much, that you could as well code the enitre editor from scratch for that ONE synth instead.
