PLS HELP: Prophet 6 Left/Right Output Volume Not Equal
« on: March 20, 2021, 09:28:07 PM »
Hello All, first post here :D
I've got all stereo effects/pan spread, etc. off on my P6, however, my Left out is coming in about 1.5db louder than my Right out.
What would be the reason for this? Is there a way to calibrate it? THXXX
Jonny T
Re: PLS HELP: Prophet 6 Left/Right Output Volume Not Equal
« Reply #1 on: March 21, 2021, 02:16:30 AM »
Always the first check is to swap the output cables round at the synth end, is it still hotter on the same channel?
« Reply #2 on: March 21, 2021, 02:24:43 PM »
Hey Bob, good call.. however, when I swap the cables, the left channel (now the right channel on my interface) is still hotter. Also tried switching cables with a different synth and same story. Other thoughts?
« Reply #3 on: March 24, 2021, 02:02:26 AM »
Sorry to ask the obvious, are settings for each channel set the same on the interface? And same question for the DAW (if you’re using one)?
jago
« Reply #4 on: March 24, 2021, 11:19:10 AM »
Have you checked the headphone output as well?
Prophet X. Prophet 12. Prophet 6. OB-6. Modal 008. Eventide H9000R. Avid S3.
