With OS 1.7.4 there is a workaround to use pressure/Z in MPE mode: on your controller (Linnstrument in my case) you must send out "polyphonic aftertouch", NOT "channel pressure".
This way, you can play polyphonic pitch bends and use polyphonic aftertouch on the Prophet.
Unfortunately this is not following MPE spec:
These per-note messages are limited to Note On, Note Off, Channel Pressure (for finger pressure), Pitch Bend (for X-axis movement) and CC74 (for Y-axis movement).
For messages that apply to all notes, like Program Change, CC7/volume, CC64/Sustain, etc., these are sent over a separate "Master Channel" (called "Main Channel" on LinnStrument),
source:
https://www.rogerlinndesign.com/support/support-linnstrument-what-is-mpeThe issue with using polyphonic aftertouch in MPE mode instead of channel. pressure is that Ableton and Bitwig (and perhaps other DAWS too) cannot handle this. When you record MIDI notes in MPE mode, the polyphonic aftertouch gets automatically translated to channel pressure.
Logic can handle the specific requirements for the Prophet without problems, but all MPE MIDI you recorded before cannot now be used for the Prophet.
