What can be done with MPE on the Prophet 6
« on: March 11, 2021, 01:44:20 PM »
Sorry for this kinda newbie question, but could someone explain what can be done if we enable MPE on the P6?
For instance, with a dedicated MPE keyboard, is it possible to open the filter according to pressure per key pressed ? Or assign a LFO per key pressed (more lfo with pressure on a specfic key ?).
In one word, what kind of parameter can be used per key ?
Thanks for enlighting me  :)
the8bitdeity
  • 48
  • Ham handed synth enthusiast
Re: What can be done with MPE on the Prophet 6
« Reply #1 on: March 11, 2021, 03:01:39 PM »
firstly, the Prophets already respond to polyphonic aftertouch. If you send it Poly Aftertouch, it will use the Aftertouch modulation on a per voice capacity, but if you send it Channel Aftertouch it will use it across all voices.
As for MPE, the MPE menu allows you to configure what CC74 will modulate, which is commonly what MPE uses for "Y-Axis" modulation. For example the Linnstrument uses up / down on the individual key as a modulation source (that is to say where you're pressing the key on the top / bottom of the key, not pressure).
Kijimi, Xerxes mk2, OB6D, P6D, Prophet 5D (expanded), OB-X8D, Hydrasynth, Pro 3, Wavestate, MS20D, A4mk2, ARmk2, MC202, Avalon, Syntakt, Octatrack, NLDR, H9000, Digitone, Deckard's Dream mk2, Isi-Nin, Roland System 500 + other Eurorack
