Vintage Knob Feature Request:Either:
1. Adjust the Max Values of the Vintage Knob so Filter ADR Timing is scaled down by a factor of 2x and Filter Cutoff Values down by a factor of 5x. (and a couple other slight variations to values as outlined in video below... ie: add a bit of offset between Osc1/2 variance, shuffle max delta between voices)
OR
2. Add another variant of the Vintage Knob, selectable from Globals, so instead of just "Off, On" choices, we have "Slop, Vintage 1, Vintage 2" For Vintage 2 mode, use the exact same methodology and logic, but just change the max values as outlined/recommended in the video.
https://www.youtube.com/watch?v=G7tdp5tvopUBased on the analysis I did, and being a programmer (I know, dangerous statement following..
), I'm guessing this should be a fairly trivial task / easy to implement... seems that there's probably just a small lookup table of max offsets stored, and by changing a couple dozen stored values and re-saving firmware, it could be done in a short period... of course, I could be mistaken... may be more involved, but the request remains
I'm really stoked on having the Vintage Knob, and the methodology for how its implemented is great... but based on working on this topic of voice variance / voice modeling over the past few years, I just think that adjusting the max values will result in it being even better throughout the entire range of the knob...
improved vintage character at lower values and
also still be usable at 3/4 or even max settings, without having extremely dissonant filter and env temporal offsets.
FYI: I didn't mention in the video: I know the initial response might just be "well, just turn the knob down, problem solved"... while that holds true for many other situations, it doesn't work well in this case, because this one knob controls a large variety of different offsets, and some of them are "off by different magnitudes". ie: In my opinion, the Osc 1/2 tuning total offset range is perfect, the ADR timing offsets need to be scaled down by 2x, and the Cutoff variance needs to be scaled back by 5x or so to be more musical/usable. So, if I turn the dial way back to avoid the extreme dissonance in filter variance, then I loose all the interesting offsets to Osc tuning per voice.
Again, really great job overall on the implementation, and thanks for porting the Vintage Knob over to P6! It's great to have on this synth.
