MIDI issue - Phasing , double notes with Local Control ON
« on: February 26, 2021, 02:02:59 PM »
I have a problem with my Prophet Rev2.If I leave "local control" on in the Global settings and then open Cubase or Logic with the Rev2 as External Instrument, I hear a sort of phasing/doubling effect on every note I play.
This only happens when I set the Rev2 as a midi input and output. If I use another keyboard I don't have this problem, but then I can't record controller movements (like the cutoff etc).
I made an audio clip of this, the first 8 bars are with "local control OFF" and the last 8 bars are with "local control ON", see attachment.
The rev2 is connected via MIDI cables to a MOTU Midi Express 128 and output 1-2 go directly to a UAD Apollo 8, with the UAD Console mixer channels set to mute.
Does anyone have any idea what could be going on here?
timboréale
  • 205
  • MIDI nerd
Re: MIDI issue - Phasing , double notes with Local Control ON
« Reply #1 on: February 26, 2021, 02:07:39 PM »
That's literally the situation Local Control OFF is designed to fix. Leave it off for your case, and watch this to understand more:
