1.6.7
1.6.7
« on: February 26, 2021, 12:45:44 PM »
thirteen_engines
  • 180
Re: 1.6.7
« Reply #1 on: February 26, 2021, 03:15:03 PM »
Cool! Not sure what's new in this release, other than the correct firmware number but ...
Don't forget to reset globals with write + globals and then, if you'e using the vintage setting to reset it to vintage. I forgot that at the last firmware update and wondered why vintage wasn't working like before.
Cheers,
Keith
« Last Edit: February 26, 2021, 03:40:52 PM by thirteen_engines »
Re: 1.6.7
« Reply #2 on: February 28, 2021, 06:22:27 AM »
In my opinion it is the official version 1.6.6 which displays "1.6.7" at startup  :) (it is better than "6.0.2" :-[)
I performed the update. It stuck at the end of the upgrade process (suddenly displaying "111" after the second countdown reached "1"). I waited 5 minutes and turn it off.
It displayed "1.6.7" when I turn it on few seconds after.
Upgrade successful. :)
« Last Edit: February 28, 2021, 06:24:10 AM by lowan »
Re: 1.6.7
« Reply #3 on: February 28, 2021, 07:28:04 AM »
Question to the Sequential team:
I have 1.66beta installed. Is there any reason (code changes, bug fixes) to update to 1.67, or is this just the name of the official version? I would prefer a definite answer over guesses.
Re: 1.6.7
« Reply #4 on: February 28, 2021, 08:05:07 AM »
Don't presume the Sequential staffers read every post here.  They're busy working at home, so the communications are worse than usual.  If you want a definitive answer from the mothership, contact them directly.
Re: 1.6.7
« Reply #5 on: March 02, 2021, 04:43:19 AM »
I get an E.r.1 error message after transfer...? Anyone had this before?
Re: 1.6.7
« Reply #6 on: August 08, 2021, 02:31:57 PM »
I had the same behavior on the second time I ran the firmware update. Works fine now. The first time I ran it, it never did either count down and the display showed "t 8". I tried to play a few patches and it was not right, but running it a second time fixed it.
