Can you poly chain two desktop Evolvers?
« on: February 13, 2021, 03:21:12 PM »
Re: Can you poly chain two desktop Evolvers?
« Reply #1 on: February 13, 2021, 04:30:19 PM »
From the Evolver Desktop Operation Manual, pg. 16:
Poly Chain: (see table below) Poly Chain is used to link multiple Evolvers into a
polyphonic system by selectively passing MIDI data through to the MIDI out jack
where it can be routed to another Evolver. Note that MIDI clocks are handled
separately per the MIDI Clock parameter. Settings:
Display   Poly Chain Status
OFF    -    MIDI operation is normal.
ALL     -    All MIDI information is passed through to the MIDI out jack
not     -    Only MIDI note data is passed through to the MIDI out jack.
« Reply #2 on: February 13, 2021, 09:28:35 PM »
Thank you very much!! :D
