« Reply #1 on: February 11, 2021, 01:14:08 PM »
So MIDI clock can send both transport control (play, stop) as well as clock sync. If you turn the OB6 onto "NSS" this is "no stop no start" which means it will sync to the clock but not start the transport of the OB6 (sounds like what you want).
The issue of clock not being sent while playing is likely going to happen regardless of the DAW you use.
Are you implying that with Clock set to "IN" the OB6 doesn't care about Reaper playing or not?
![](https://forum.sequential.com/Themes/Reseller-child/images/ip.gif)
Kijimi, Xerxes mk2, OB6D, P6D, Prophet 5D (expanded), OB-X8D, Hydrasynth, Pro 3, Wavestate, MS20D, A4mk2, ARmk2, MC202, Avalon, Syntakt, Octatrack, NLDR, H9000, Digitone, Deckard's Dream mk2, Isi-Nin, Roland System 500 + other Eurorack
