Odd MPE Behavior with Prophet 6 1.6.6 and Live 11
« on: January 25, 2021, 06:29:27 PM »
I've noticed odd MPE behavior with the 1.6.3 and 1.6.6 beta firmwares with Live 11.
I have a Roli Lumi Keys and a Roli Seaboard which are both MPE controllers. When I setup my P6 and Ableton in MPE mode the Prophet doesn't always play notes when I press a key. If I press the same key say 10 times in a row it'll sometimes play and sometimes be silent. It actually does it in a pattern that I figured out. 5 plays, 1 silent, 1 play, 8 silent [repeat].
The way I've got Live 11 setup is:
Roli hooked up via USB and turned on in Ableton Midi settings (and configured as an MPE device)
A empty midi track routed externally to my P6 Desktop via USB:
Midi From: All Channels
Midi To: Prophet 6 [MPE]
In the P6 I've got the Midi Channel config set to MPE.
Whats odd about this is when I open Logic and just play my controller the odd behavior is gone (but its hard to test out if MPE is fully working for me)
Here's a screenshot of my Ableton settings:
Re: Odd MPE Behavior with Prophet 6 1.6.6 and Live 11
« Reply #1 on: January 26, 2021, 01:16:45 AM »
Normal MPE settings are to have Ch1 global and 2-16 as notes ... but P-6 only using 2-7 for notes for its 6 voices. I needed to set my Linnstrument to use only channels 2-7 accordingly, then dropped notes disappeared ... I haven't got my Roli out to try yet, but I'll assume I need to do the same thing ... I don't have the 11 Beta to know what they've done there ...
« Reply #2 on: January 27, 2021, 01:14:36 PM »
I have the same issue, I read somewhere that Ableton cycles through all the midi channels 2-16 when sending MPE, and it's not even fixable with whatever controller you are using because ableton will still do its thing. Haven't found a solution for that yet, I believe Ableton's forums is the right place to ask though
« Reply #3 on: February 24, 2021, 11:42:51 AM »
It's still a problem now that Live 11 is out of beta. Typical Ableton, unfortunately :( I don't understand why they insist on actively rewriting our midi, but I doubt there's anything Sequential could do about it.
Pym
  • 142
« Reply #4 on: February 24, 2021, 08:18:32 PM »
I brought it to their attention during the beta period, it is a larger fix than they could do before release
Dave Smith Instruments
the8bitdeity
  • 31
  • Ham handed synth enthusiast
« Reply #5 on: February 25, 2021, 03:46:30 PM »
Hi, glad to hear they're aware of it. I'm unfamiliar with the MPE spec, but is it expected that MPE sources offer the ability to limit their channel range? I wasn't sure if the requirement was put onto sources or sinks.
P12R, uWXT, Kijimi, Xerxes, OB6D, P6D, Hydrasynth, System 8, Pro 3, Wavestate, Peak, MS20D, A4mk2, ARmk2, MC202, Avalon, Model:Cycles, Octatrack, NLDR, H9000, Digitone, Deckard's Dream mk2, Roland System 500 + other Eurorack
