Rev 2 Interference pls help
« on: January 25, 2021, 07:20:48 AM »
Hello,
I have a Rev 2 8 and i cant get a clean signal out of it! I am using a Komplete Kontrol 6 mk2 for the input and a normal 3.5mm Jack. I will upload the Interference here maybe u recognise it ? Thx for your help!
https://1drv.ms/u/s!AneuCczM-WrngadNLIv1Ls5R8lqREg?e=oMePNz
« Last Edit: January 25, 2021, 07:22:27 AM by SebastianPfeifer »
Re: Rev 2 Interference pls help
« Reply #1 on: January 27, 2021, 07:27:50 AM »
The link doesn't work on my phone but it sounds like you've got a ground loop. try running your Rev 2 through a stereo DI box. do not use a ground drop. The Rev 2 has unbalanced outputs so you will need a stereo DI box to get rid of the interference. they are not very expensive.
maxter
  • 329
« Reply #2 on: January 27, 2021, 08:59:53 AM »
Yup, the audio file too sounds like a ground-loop (from USB specifically, it sounds like to me)
Have you made any other connections on the Rev2? Like USB? If so, try disconnecting the USB cable to see what the result is in the audio. If the problem disappears, use MIDI DIN instead of USB, that usually does it. If not, try a stereo DI box like Josh proposed. It's kind of "hit-and-miss", in some cases it works.
« Reply #3 on: January 29, 2021, 02:25:27 AM »
Alright thank you guys i will try the DI!
