Rev 1/2 vs rev 3 filter volume
« on: January 24, 2021, 02:30:45 PM »
Hey,
I noticed my rev 1/2 filter setting isn't as loud as when I set it to rev 3. The 1/2 seems approximately -3dB volume..
Is anyone else experiencing this?  :o
I hope nothing is wrong with mine.  :-\
Cheers,
echoloch
Korg Mono/Poly, Sequential Prophet 10 Rev4, Buchla Music Easel
S_A_P
Re: Rev 1/2 vs rev 3 filter volume
« Reply #1 on: January 24, 2021, 07:22:25 PM »
I dont know if I would say the difference is volume related as much as the Rev 3 is brighter while the Rev 1/2 is more of a darker tone. I guess it would depend on where you hear the 3db difference?
« Reply #2 on: January 25, 2021, 02:16:55 AM »
It is not only noticeable by ear but I can see it on my interface input volume.
I guess I could post a sample on soundcloud.
EDIT: sample https://soundcloud.com/echoloch/rev1-23
« Last Edit: January 25, 2021, 02:28:56 AM by echoloch »
  • 1657
« Reply #3 on: January 25, 2021, 06:09:06 AM »
Have you already patched the OS to 1.2.0?
If so and it's still doing this, I would send support a note.  I don't get a volume difference like that between the two filters.
I find the difference heard on each filter type depends largely on the type of sound, but to me the Rev 1/2 filter tends to sound a little brighter due to the more linear nature of the envelope.  The Rev 3 filter is more logarithmic than linear, which rounds off the high frequencies more abruptly, rather than filtering on a more gradual slope.
« Reply #4 on: January 25, 2021, 12:55:53 PM »
Yes, I updated the OS as soon as I received mine. I used MIDI-OX and it went smoothly as far as I could tell...
Maybe I should try to update it again before I shoot Andy a message?
Anyways, thanks you two for the input!
cheers,
echoloch
« Last Edit: January 25, 2021, 01:10:49 PM by echoloch »
« Reply #5 on: January 27, 2021, 04:25:20 PM »
I've found the same... I am not sure but i think it may have been improved a bit between pre 1.2 and post 1.2. It was jarring before now It sounds more like a difference in filters as opposed to a massive drop off. I would be surprised if there wasn't a change in 1.2 that had addressed that and I am just not noticing it as much now. .... I almost wanna downgrade to double check my mind set to be sure I am not talking out my booty.
« Reply #6 on: January 27, 2021, 11:22:55 PM »
After toggling between filters with the presets I've concluded there is nothing wrong with mine. It seems the volume difference is dependent on the particular sound/ patch you are going for. I love how you get both filters.. it really gives the rev 4 this ying yang, dark side, light side vibe.  8)
« Reply #7 on: February 13, 2021, 06:56:25 PM »
I've updated to 1.5 from 1.2 and this problem has ceased, though it wasn't mentioned in the patch notes. It was a  very pronounced issue for my P10 before.
kyps
« Reply #8 on: February 14, 2021, 12:12:12 PM »
Hi guys,
I just got my p10, I just have a question,
Is that normal that when you make an unit patch you can have a « higher »sound about the filter when you turn on the « enveloppe amount » ?
Is that normal ?
« Reply #9 on: February 15, 2021, 10:13:00 AM »
Hi guys,
Is that normal ?
Yes, that’s totally normal.
  • 1657
« Reply #10 on: February 15, 2021, 10:24:04 AM »
Hi guys,
Is that normal ?
It's a bit different than most other synths, which seem to generally init patch with filter wide open.  I assume it's because the original P5 had this characteristics.
