Prophet 6 Full polyphony only in local off
« on: January 14, 2021, 03:56:15 AM »
Hi everyone,
When i'm in local on i've got only 3 notes polyphony.
In local off i've got 6 notes.
Am i missing something ?
Thx ;-)
« Last Edit: January 14, 2021, 03:57:58 AM by fkclub »
jok3r
  • 342
Re: Prophet 6 Full polyphony only in local off
« Reply #1 on: January 14, 2021, 04:00:41 AM »
Sounds like you have a midi loop in your setup. If you use a DAW or other device that sends the midi commands from your synth back to your synth, it will trigger notes twice... the synth itself triggers a voice and the your DAW triggers a second one. Therefore you got half the polyphone with Local on.
« Reply #2 on: January 14, 2021, 04:08:28 AM »
Thx a lot , you are right !!
It works if i turn off my daw.
I'm plugged with midi in and midi out.
how to cancel this loop ?
jok3r
  • 342
« Reply #3 on: January 14, 2021, 04:40:33 AM »
It depends on your DAW. In most DAWs you can configure in- and output ports of the channel you are using for your synth. You could stop the output back to the synth there.
Some DAWs have a monitoring setup that reads the input only when recording and sends to the output only when playing back. Perhaps you could look for something like that.
« Reply #4 on: January 14, 2021, 11:38:53 AM »
Thx a lot for your great help man , i will try this ;-)
Take care
