NRPN for Sequencer and parts ABCD
« on: January 13, 2021, 12:27:35 PM »
Hi!
Anyone know what these NRPN’s are? Or if they are available at all? Looking for the NRPN for Play on the sequencer and also for parts ABCD if possible. Wanted a hands free midi control option since I play guitar and keys simultaneously.
Works like a champ on my Rev2(the sequencer play NRPNs for Part A and B).
Re: NRPN for Sequencer and parts ABCD
« Reply #1 on: January 13, 2021, 02:09:06 PM »
Per the manual, Appendix F: MIDI Implementation, Control NRPN Data section, NRPN 4188 is supposed to be for Sequencer Play/Stop though I didn't see it sent. Or sending MIDI start/stop.
Glancing at MIDI NRPN data from pressing the A/B/C/D buttons, it looks like the following may work:
A   431
B   432
C   433
D   434
When a button is pressed, that one is sent first with a value of 1 then the other three NRPNs are sent with value 0. So, switching to D would probably be sending the following NRPNs:
nrpn 434   1
nrpn 431   0
nrpn 432   0
nrpn 433   0
In case they might be useful:
Seq Mode      nrpn 422   0-2  Normal, Gated, Trigger
Seq Direction nrpn 423   0-3  Fwd, Rev, Fwd/Rev, Random
Slew          nrpn 374   4-5  Off, On
I did notice a possible UI bug after changing the A/B/C/D button selection via NRPN where the previously selected button could not be selected unless you select another first including the one just selected via NRPN. Will need to test out further before submitting as an issue.
Hope that helps.
« Reply #2 on: January 13, 2021, 05:51:17 PM »
Thanks so much Jeff!
I’m going to check these out. I just remembered as I’m typing this that my squarp pyramid has a midi monitor. Doh! I appreciate the response greatly!
« Reply #3 on: January 25, 2021, 10:12:19 PM »
Jeff,
You are correct NRPN 4188 does nothing via triggered by DAW(logic) or my cymatic LP-16. Whereas, the same NRPN that is spec’d for my Rev 2 works flawlessly with the exact same global settings.
I’ve tried everything and no luck getting that sequencer to trigger externally.
« Reply #4 on: July 15, 2022, 02:26:25 AM »
Chiming in here, this is apparently still broken. Can @cbmd or @Pym confirm?
  • 1800
« Reply #5 on: July 21, 2022, 06:31:03 PM »
Man, this would be such a bloody cool feature to have!
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
« Reply #6 on: September 02, 2022, 08:47:26 AM »
follow
« Reply #7 on: September 28, 2025, 03:20:07 PM »
Is NRPN completely broken on latest PRO3 firmware?
I can't get it to work. Trying to control it from Faderfox EC4. Works fine with Summit and Deepmind, no idea why it doesn't seem to work with PRO3
Additionally, no matter if Param control is set to CC or NRPN in settings, it always responds to CC.
« Last Edit: September 28, 2025, 03:44:24 PM by RadekPilich »
« Reply #8 on: September 29, 2025, 02:00:40 PM »
Igonere / delete my previous message, I've figured it out, the issue was Faderfox related.
The Faderfox display mode has to be switched to 1000 or 9999. When in the lower number modes, the NRPN messages increase by multiples of 128. Only when the display mode is switched to higher resolutions, the NRPNs increment by 1.
