Frequency Modulation of Both Oscilators?
Chi
« on: May 12, 2016, 08:13:31 AM »
Is there a way to modulate each OSC independently? I'm looking to approach a note from below with one OSC and from above with the other - with both ending at the same pitch. I can use the filter-env via polymod to shape OSC 1's FREQ but it seems there is no way to do something similar to OSC 2's FREQ. Using the LFO on one OSC 2's FREQ means that the both OSC's will not stabilize to the same note since OSC 2 will continue moving up/down with the LFO. Using Aftertouch doesn't give enough control to have a consistently smooth sweep either. I'm guessing that using MIDI CC 75 will not help either - looking at the manual it has 60 discrete values so I assume it is a stepped control like the pot. Am I missing something or is it simply not possible to do this with the P6?
