MPE setting for external MPE keyboard (Keith McM Kboard Pro4)
« on: January 07, 2021, 11:17:20 AM »
I have used the Pro4 with MPE to successfully control a Deckards Dream but when I put the P6 on MPE (Global setting above midi channel 16) it doesn't respond when certain keys pressed on the Pro4. Varies by octave. The midi converter box of the Pro4 is blinking that midi is being sent, but the P6 doesn't make a sound with certain keys.
Changing to ALL midi channels, all the key presses are sounded but no x axis vibrato.
Not sure if Param Xmit and Rcv should be CC or otherwise.
« Last Edit: January 07, 2021, 11:18:54 AM by markottosmith »
Re: MPE setting for external MPE keyboard (Keith McM Kboard Pro4)
« Reply #1 on: January 07, 2021, 02:20:26 PM »
You will need to limit the KBoard to 6 note polyphony on channels 2-7. Otherwise, you will be broadcasting on channels that the P6 doesn't respond to.
(2) P6 Desktops, Prophet VS Rack, P10 Desktop, OB6 Desktop
