WAV2Pro3 Intro & Support
  • 1536
« on: January 01, 2021, 12:56:03 PM »
Happy 2021, all you Pro3ers in Pro 3 Land!
I'm excited to introduce WAV2Pro3, an online wavetable generation and sharing platform for the Sequential Pro 3.
This application is not meant to replace Sequential's wavetable generator, but provides an alternative with a different philosophy. Specifically:
(1) WAV2Pro3 designed to use the output of wavetable plugins like Serum, Vital, and others. These tools typically generate a single WAV file rather than multiple WAV files required by Sequential's generator.
(2) WAV2Pro3 can accept wavetables with any number of waveforms. It will automatically evenly (as possible) downsize wavetables larger than 16 waveforms, and it will fill in gaps with linear interpolation if your wavetable contains fewer than 16 waveforms. You can simply export from Serum and upload the resulting file to WAV2Pro3, with no need for additional curating or processing.
(3) WAV2Pro3 allows you to use any number wavetables in a single session.
(4) Like its older brother, WAV2Evolver, WAV2Pro3 encourages sharing your favorite wavetables to a community wavetable library.
If you use Serum or other wavetable editing software, please give it a try!
http://wav2pro3.beigemaze.com/
Pro 3 #1640
Other: Make Noise modular, Circuit Tracks, MicroBrute
Re: WAV2Pro3 Intro & Support
« Reply #1 on: January 01, 2021, 06:22:43 PM »
Awesome. Looking forward to checking this out!
  • 1536
« Reply #2 on: January 03, 2021, 10:40:22 AM »
New Feature
WAV2Pro3 now accepts Pro 3 wavetable sysex files as uploads. This allows you to
(1) Change the wavetable position of wavetables that you've already generated, and
(2) Share existing wavetables without needing the original WAV file
Pro 3 #1640
  • 1536
« Reply #3 on: February 17, 2021, 03:26:04 PM »
New Feature
WAV2Pro3 now generates and accepts direct links to wavetables in the Wavetable Library, for easy sharing to a position of the recipient's choice. Like this:
http://wav2pro3.beigemaze.com/?0bfdbc7df1485061c29d2f8f489fc527
Pro 3 #1640
  • 1536
« Reply #4 on: February 20, 2021, 02:31:12 PM »
New Feature
WAV2Pro3 may now be used to generate wavetables with a keyboard split point. That is, your wavetable file may contain one wavetable that is active in the lower part of the keyboard range (up to around F#3), and a completely independent wavetable that is active in the upper part of the keyboard range.
I'll post a tutorial of this technique soon.
« Last Edit: February 20, 2021, 02:33:12 PM by chysn »
Pro 3 #1640
  • 1536
« Reply #5 on: February 21, 2021, 12:49:19 PM »
Pro 3 #1640
« Reply #6 on: February 21, 2021, 02:01:31 PM »
Thx for this super tool Chysn !  :-)
Prophet X & Pro 3
« Reply #7 on: February 21, 2021, 02:09:10 PM »
Please see https://www.youtube.com/watch?v=6wprXf7GqsE&feature=youtu.be
Very cool.  Thanks for putting together a tutorial on this!... Definitely gonna experiment with this.
Sequential Pro 3 and Prophet Rev 2, Deepmind, PolyBrute - Sound Sets, Patch Banks - Available on Sellfy: https://sellfy.com/sounddesign/
  • 1536
« Reply #8 on: March 13, 2021, 02:44:35 PM »
Update
WAV2Pro3 is now available at
www.wav2pro3.com
for easier access. The previous URL is, and will remain, valid.
Pro 3 #1640
RAFH
« Reply #9 on: September 19, 2021, 03:01:47 PM »
Update
www.wav2pro3.com
Tried visiting the site but got an error saying the site could not be reached. Is it still up , or has it moved ? Thanks!
Sequential Pro-3, Elektron Analog Heat MK2, Elektron Analog RYTM MK2, Elektron Analog Four MK2, Pioneer Toraiz SP-16, Behringer TD-3, 104hp Modular Synth w/Mutable Instruments modules, 48hp Modular FX box with Intellijel Rainmaker and Audio I/O, Eventide H9 MAX
  • 1536
« Reply #10 on: September 19, 2021, 05:16:00 PM »
Update
www.wav2pro3.com
Yikes, it looks like the server is down! I'll have to drive out to the colo center tomorrow and see what's up.
Pro 3 #1640
  • 1536
« Reply #11 on: September 21, 2021, 07:32:38 AM »
Update
www.wav2pro3.com
I suspect that somebody inadvertently powered down my server in the shared cabinet. I went to the facility and restarted, and it's back in business
Pro 3 #1640
  • 1536
« Reply #12 on: February 12, 2022, 09:09:39 AM »
New Feature
I've added a new feature to WAV2Pro3, an "Auto (16 Waveforms)" setting under Frame Size. This option simply chops whatever WAV file you upload into sixteen equal parts and generates a wavetable, without regard for wave boundaries. It will interpolate as necessary based on the size of the data.
It's definitely the easiest way ever to create a Pro 3 wavetable. If your file happens to consist of 16 single-cycle waveforms, it'll work just as you expect. Otherwise, anything can happen. I've put in some vocal samples and gotten some cool vocal formant results. It invites experimentation!
"We don't make mistakes, just happy little accidents."
--Bob Ross
« Last Edit: February 12, 2022, 10:06:52 AM by chysn »
Pro 3 #1640
« Reply #13 on: February 14, 2022, 12:29:04 AM »
Good bless you. Great feature! Thanks.
