Hi all,
Recently became the owner of an OB-6 and love it more than anything else I own. I am, however having some issues with using Ableton to control it. I've noticed when I connect it via USB and set it to receive MIDI clock, it is always off by a bit when I see the tempo readout in the clock section. There also seems to just be a general jitteriness to MIDI sent to it.
As an experiment, I set the OB-6 to send clock into Ableton, and just as well! Ableton's tempo readout will show something off by about 1.2-1.8 BPM than the tempo shown on the OB-6 clock, and it also will change on every 1/4th note by a small amount.
Now, I've had a bit of poor performance of MIDI over USB with other synths before, but never anything this bad. Is there something wrong with how I've set it up, or is something actually wrong with my unit?
Settings on the OB-6 are:
- MIDI Channel = 1
- MIDI Clock = I have cycled through every option, but none seem to work right
- Clock Port = USB
- MIDI Control = On
- MIDI Sysex = USB
I've gotten the OB-6 to send me the arpeggiated MIDI into Ableton, so I know they are talking to eachother. But there just seems to be something off about tempo, MIDI and sync. I know MIDI over USB is notoriously bad, but... this bad?
Settings in Ableton:
- Track/Sync toggles on for both input and output on the OB-6 ports
- Sync Type = MIDI Clock (on the input)
- MIDI Clock Type = Pattern (on the output)
I'm running Windows 10, Intel Core i7 2.60GHz, 16GB of RAM and an Audient iD44 interface if that provides any relevant context. The iD44 does not have MIDI outs, but I can fish out an old USB Scarlett interface just to test, and maybe send MIDI to the OB-6 via actual MIDI cables and see if the same issue is present.
Any thoughts would be greatly appreciated.
