Problems matching DAW/Sequencer Tempo
ARNK
  • 124
    • Returning to Zero
« on: December 15, 2020, 09:46:44 AM »
I realize you’re not able to record MIDI notes/info from the sequencer, but say I want to record the sequence in audio...
In Cubase, I’ve setup project synchronization but when my project is set to 120 BPM the sequencer tempo loses it’s mind and registers at around 300-500 BPMs when I click play on the DAW transport bar.
Changing the time division or Tap Tempo on the Pro 2 doesn’t do anything. I also know they’re communicating because when I press stop inside the DAW the sequencers tempo matches the project tempo again.
Cubase 11, Windows 10, latest firmware.
