Sequencer: modwhell and pitchbend automation
« on: December 09, 2020, 02:30:52 AM »
When I discovered the Pro 3 sequencer, I wanted to automate "modwell" roulette and pitch bend. Only, I did not succeed.
Do you think it is possible to "automate" these functions?
__FR
Sequencer : automation de la roulette et du pitchbend
En découvrant le sequencer du Pro 3, j’ai eu l’envie d’automatiser la roulette « modwell » et le pitch bend. Seulement, je n’ai pas réussi.
Pensez-vous qu’il soit possible « d’automatiser » ces fonctions ?
Paper & Pencil
Re: Sequencer: modwhell and pitchbend automation
« Reply #1 on: December 09, 2020, 02:50:26 AM »
The modulation and pitchbend wheels are only modulation sources, not modulation destinations. So you have to assign whatever parameter you'd like to control with the modulation wheel to one or multiple sequencer tracks. As for the pitchbend wheel: You may use one sequencer track for controlling the oscillators' coarse or fine tune parameter and then enable SLEW as an alternative.
« Reply #2 on: December 09, 2020, 02:53:41 AM »
Effectively !  8) :)
Thank you for the details. I'm going to try.
Have a good day :)
Paper & Pencil
