Prophet 5/10 Beta Main OS 2.0.6 and Panel OS 1.1.3
cbmd
  • 515
    • Sequential
« on: December 07, 2020, 03:12:20 PM »
OS updates are compatible with both the Prophet 5 and 10 keyboards and modules. YOU MUST LOAD THE MAIN AND PANEL UPDATES SEPARATELY AND POWER CYCLE AFTER EACH INDIVIDUAL UPDATE COMPLETES. After updating and power cycling the Main OS will display as "2.0.6". After updating and power cycling the Panel OS will display "1.1.3".
**After loading the Panel OS, wait for the display to read "rst" before power cycling**
To check currently installed Main OS, hold GLOBALS and press the program "1" button. To check currently installed Panel OS, hold GLOBALS and press the program "2" button.
When the OS file is transmitted to the synth a count from 0 to 100 will be displayed on the synth's main display to indicate reception of the OS file.  Once the count reaches 100, a second count from 10 to 0 will commence indicating writing of the OS to internal memory.
**DO NOT POWER THE SYNTH DOWN WHILE THE SECOND COUNTDOWN IS ACTIVE**
The synth will return to normal operating after the writing stage completes.  Power cycle the synth off and back on to finish the update.
ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!!
Not that we're expecting bad things to happen, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I hadn't backed that up..."
We do not recommend using the following MIDI interfaces for sysex transfers as we have had multiple users experience problems with them:
    Native Instruments Maschine
    Digidesign Mbox/Mbox2
    Digidesign 001/002
    CME U2MIDI
To check if the OS update was properly installed, restart the unit, hold the GLOBAL button and press the 1 button.  The 3 digit main OS version number will be shown on screen.
If your OS update failed:
1. Update your MIDI drivers for your MIDI interface to the latest or last known stable version
2. Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
3. Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
4. In Windows with MIDI OX on Windows XP:  Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
5. Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with Sysex transfers and whether there is a solution specific to your interface
6. If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with sysex transfers
**INSTALLATION NOTE: It is recommended to reset globals and clear calibration after updating from any OS below Main 1.5.0.  You will need to re-tune the synthesizer from scratch following the update.
RESET GLOBALS : hold RECORD and press GLOBALS
CLEAR CALIBRATION: hold RECORD and press TUNE
CHANGELOG
P5/10 Main 2.0.6
Bug Fix: Added CC91 to adjust stack split mode
Bug Fix: Sound version fix for loading patches from previous OS’
Various small bug fixes.
P5/10 Main 2.0.4 / Panel 1.1.3 Changelog
New Feature: Q Compensation adjustable per patch (third row global option 3, Vin=default, tied to vintage knob, PRG=per program, accessed by holding filter REV button and pressing PRG 1-8)
New Feature: Adjustable Velocity and Aftertouch Amounts per patch
New Feature: High Note Priority Added for UNISON
New Feature: Link Layers by holding UNISON and pressing PRESET, changes to panel will affect both layers simultaneously
Changed Feature: Adjust balance between programs in a split/stack by holding PRESET and turning the volume pot.  Volume pot centered is equal volume on both patches.
Bug Fix: Module Only - Certain params being set to 0 when Live Panel mode entered, regardless of physical pot position
Bug Fix: AT/Velocity/Voice Allocation settings not retained after power cycling if an alternate tuning is selected
Bug Fix: in split mode, value indicator LED only shows stored value for layer A
Bug Fix: No MIDI control to indicate switch between layer A/B in stack/split mode - Assigned to CC80
Bug Fix: reduce unison detune on 2nd voice card in Unison 2 mode
Bug Fix: After the Mac comes out of sleep mode, MIDI not transmitted from the synth via USB until USB cable removed/reinserted.
Prophet5 Main 2.0.1 and Panel 1.1.1:
Bug fix [Main 2.0.1] - Basic Program shortcut (hold RECORD and press PRESET) no longer works correctly after updating to Main 2.0.0
Bug fix [Panel 1.1.1] - Master Volume does not update correctly
Bug fix [Panel 1.1.1] - Global detuning experienced until Master Tune manually updated
Prophet5 Main 1.5.2:
Bug fix - occasional dropped notes
Bug fix - MIDI clock present at MIDI IN port while powering on instrument causes MIDI IN to not work
Bug fix - changing release/sustain global drops OSC A freq 1 octave
Prophet5 Main 1.5.0:
Main 1.5.0
Feature: New 3rd row of Globals, accessed by holding BANK SELECT and pressing GLOBALS. When the 3rd row of Globals is selected, both Globals LEDs are lit.
-  3rd row slot #1: turns 5 voice limit mode on/off (affects Prophet 10 only)
-  3rd row slot #2: selects between P5 style or Round Robin voice allocation modes
Feature: New Poly Unison mode. Hold UNISON and select “PU2” using the Inc/Dec buttons. Each note is allocated two voices.
Prophet5 Main 1.2.0:
Fixed bug: Pot Modes not working.
Fixed bug: with release/sustain global set to release, sustain pedal CC value output reversed.
Fixed bug: Noise level difference between voices on Prophet 10.
« Last Edit: May 27, 2025, 04:36:43 PM by gus »
Product Designer
cbmd
  • 515
    • Sequential
Re: Newest Prophet 5/10 Main OS 2.0.4 and Panel OS 1.1.3
« Reply #1 on: September 27, 2022, 03:59:49 PM »
New Main OS version 2.0.4 and Panel OS version 1.1.3 posted!
YOU MUST LOAD THE MAIN AND PANEL UPDATES SEPARATELY AND POWER CYCLE AFTER EACH INDIVIDUAL UPDATE COMPLETES. DO NOT SEND EACH UPDATE IN SUCCESSION WITHOUT POWER CYCLING IN BETWEEN.
If you experience a failed update, try reloading the OS in bootloader mode over DIN MIDI (USB is not available in bootloader mode). To access bootloader mode in the Prophet 5/10, hold both the pitch wheel and the mod wheel in the upmost position while powering on. You will then see "btl" in the display, indicating bootloader mode.
Product Designer
cbmd
  • 515
    • Sequential
« Reply #2 on: September 27, 2022, 04:02:08 PM »
Main 2.0.4 - Q Comp feature use instructions.
1. Hold BANK and press GLOBAL to access the 3rd row global functions.
2. Press the 3 button to select the Q comp mode selection.
3. Use INC/DEC to select between 'VIN' or 'Prg' mode.  'VIN' is the default mode already available in the instrument.
4. With 'Prg' Q comp mode selected,  press the GLOBAL button to exit the 3rd row globals.
5. Press and hold the filter REV button.  'RES' will show on the display indicating that Q Comp selection mode is active.
6. While still holding REV button, using the program select buttons 0-8 to set the amount of Q comp applied to the patch, where 8 is max Q comp.
7. The setting can be saved per patch.
Main 2.0.4 - Adjustable Velocity/Aftertouch feature use instructions.
1. Hold VELOCITY or AFTERTOUCH button.
2. Use INC/DEC to set the amount of VELOCITY or AFTERTOUCH modulation to be applied.
3. The setting affects both modulation destinations for velocity or aftertouch and can be saved per program.
Main 2.0.4 - Link layers when split/stack active.
1.  With SPLIT or STACK active, hold UNISON and press the PRESET button to link the layers for editing.  The PRESET button will blink indicating that linked layers is active.
2.  Hold UNISON and press PRESET to turn linked layers off.
NOTE: Patch level Program volume had originally been set by holding VELOCITY button and changing the program volume on screen.  You can now adjust the relative volume balance between the two patches in a split/stack by holding PRESET and turning the volume pot.
« Last Edit: September 28, 2022, 09:00:57 AM by cbmd »
Product Designer
gus
  • 281
Re: Newest Prophet 5/10 Beta Main OS 2.0.6 and Panel OS 1.1.3
« Reply #3 on: March 12, 2025, 02:36:59 PM »
New Main OS version 2.0.6 posted!
If you experience a failed update, try reloading the OS in bootloader mode over DIN MIDI (USB is not available in bootloader mode). To access bootloader mode in the Prophet 5/10 KEYBOARD, hold both the pitch wheel and the mod wheel in the upmost position while powering on. You will then see "btl" in the display, indicating bootloader mode. To access bootloader mode in the Prophet 5/10 MODULE, connect a cable from the gate OUT to gate IN, then power on. You will then see "btl" in the display, indicating bootloader mode.
gus
  • 281
Re: Prophet 5/10 Beta Main OS 2.0.6 and Panel OS 1.1.3
« Reply #4 on: May 27, 2025, 04:42:03 PM »
Production Main OS 2.1.0 and Panel OS 1.1.3 are out now and can be found on our website at the link below. If you already have Panel OS 1.1.3 loaded, there is no need to reload it.
https://sequential.com/support/download/prophet-5-10-operating-system/
