Matrix Softstrings Patch
« on: December 04, 2020, 11:15:29 AM »
Hi –
I've been trying to program this patch from OP-X plugin in my Prophet Rev2. Having once played the OB-X, I think something very similar can be achieved, but the differences between the control panels, as well as my lack of programming skills, has me a bit lost. I would really appreciate a little help.
Best
Re: Matrix Softstrings Patch
« Reply #1 on: December 07, 2020, 06:38:39 AM »
It would be easier to help if we knew how it is supposed to sound.  Without access to that particular plugin, one can only guess.
« Reply #2 on: December 08, 2020, 11:06:21 AM »
This is an audio example recorded with my mac's keyboard.
« Reply #3 on: April 26, 2021, 12:34:04 AM »
12 dB filter for sure.
Quite little KBD TRK on filter.
There is a slight animation on the Pulse waveforms (you will need to mix a couple of LFOs to the oscillator shapes. Maybe add a bit of keyboard tracking to the osc. shapes as well, to offset it).
The Tone:
You should check the Distortion Master effect; it has a Tone control which could give you an extra roll-off on the top/high frequencies (which happens naturally to old synths due to the caps acting as low pass filters on the output stage; muffling the sound a tad bit).
