What (if anything) are you using to stereo-ize yer Prophets?
Started by S_A_P, November 28, 2020, 12:11:47 PM
75 Replies 278,445 Views
Mat
Commerce
technoroom
Commerce
Quote from: bax on April 29, 2025, 03:11:20 PM
Quote from: technoroom on January 26, 2022, 02:25:35 PM
Go to https://www.technologyroom.net and scroll towards the bottom of the page. There you will find a couple sound samples. There is also an email address for correspondence.
Disclaimer: Sequential has stated both on the GS forum and to me personally, that they will not provide support or repairs on any unit that has been modified in a manner not explicitly prescribed by them (which this mod most definitely does). The reason given is that they are too small of a company to be able to support user-modified equipment.
Regards -- Randy
I can wholeheartedly vouch for and recommend this mod if anyone is considering it.  Randy is a consummate professional and excellent communicator, this mod is well-designed, and his work to implement and install it is top-flite (saying this as someone who could have performed the installation of this mod myself).  My Prophet 10 desktop is sounding better than ever (IMHO) and I am a happy camper!
bax
Thanks for the kind words, bax! It was a pleasure working with you.
Randy
558
Jr. Member
There was a question of how to vary the stereo wideness with the Prophet 10 Rev 4. Was thinking some more and came up with a new one:
Here I have routed my Prophet's Raw audio input (recorded track) out to 10 sends panned different each with 1 of 10 ProEQ3 (Studio One) eq plugins.  Then each routed back into 1 bus and recorded on 1 stereo audio track for the simple 2 audio track recording solution.  It took me a while to set up the tracks and session and incorporate 10 extra sends each with a different panning and a different EQ setting.  Then I tweaked them a little.  Here you see a little of that and also using several different programs of the Synth during the 2nd half of the short video.
https://youtu.be/jLG6GpXGyMc
(but it is actually 3 (stereo) audio tracks I am recording because I always kept a 2nd direct input recording the prophet so there would always be a stereo offset from one to the other which worked for a long time.  It takes the same amount of disk space with 2 direct ins or with the 1 in, the group of 10 FX sends and the bus routed into a 2nd in.  With the light duty native S1 ProEQ which is an excellent plugin it doesn't do anything to the CPU I will wager.  Haven't tried it live yet but that is now a template so I will see.
I am just about on the first day of working on this sound but I found the results to be pretty good so far.  It did create different stereo wideness though I didn't work on it as much as I will eventually yet.  There can be a lot of tweaking still done and trying to get the far R and far L is still needed.  The difference in the stereo field and where the notes of different EQing were heard left to right, was pretty clear in my headphones.  Real nice effect.  I found myself wanting that I could somehow randomize the 10 EQ instances over the 10 different pan arrayed sends so that every time I push a 'randomize' button it would switch the 10 EQ instances into a different one of the 10 sends randomly or maybe just start the session with a different array.
Anyone else come up with this?  It seems obvious now that I thought of it.  Someone must have tried this at some point.
The only reason I record the 2nd audio track from the bus that mixes the 10 sends, is I wouldn't like to spend the same up to 2 hours or more of a live session recording this audio output from the sends, nor would I want to try to export a mixdown without first having the audio recorded from the sends so I didn't have to burden the mixdown with all the extra plugins.  So in this way when I would do a mixdown I would just mute the raw Prophet audio and probably remove it and its FX sends before mixdown (as it is, live, I have run it off into a FX send with the fader pulled down to silent).
Prophet still sounds good.  With my setup I only need to play like once a month.  First take perfect albums with detailed video of the creation.  Anywhere from 20 minutes to 2 hours or longer.
jok3r
Full Member
Sorry, but I have to dig this up again  ;D
Is there anybody out there who already ran a P5/10 through the mono input of a Moog Matriarch to stereo-ize it and pair it with that beautiful analogue delay?
I'm thinking of selling my Matriarch at the moment... but perhaps I should keep it just for that? They could make a wonderful pair.
Shaw
Full Member
I don't think this has been suggested, apologies if it has and I'm being redundant, but to take a page out of the guitar world (another mono instrument), a wet-dry-wet setup sounds glorious.  This is more of a "process" than an "effect", and perhaps applies more to recording (it is certainly easier to do in recording).
Basically run your synth mono dry and in a parallel effects chain add stereo effects.  This has the advantage maintaining of a pure, unaltered, mono signal path.  When you immediately hit a stereo effect (chorus, flanger, phaser, etc.), the fundamentals of your original signal aren't as strong.  The wet-dry-wet routing largely solves this issue.
In the guitar paradigm, you'd use 3 different amps.  One for your dry tone, one wet/effects left, and one wet/effects right.
So a dry mono signal paired with any number (or combinations) of stereo effects:
— chorus / flanger
— stereo phaser
— micropitch
— stereo notch filters
— slap-back delays
The stereo effects add width and space to a core tone that remains fundamentally rock solid.
sdiedrichsen
Commerce
Quote from: Analog Prophet on June 19, 2023, 04:19:22 PM
Made a short video how I get the Prophet 5 to stereo spread the voices:
https://youtu.be/Bbi7n26i1JE
That's how I do orchestral arrangements, but I duplicate the polyphonic version and mute the notes I don't want on that track.
Best,
Steffan
sdiedrichsen
Commerce
Quote from: technoroom on April 30, 2025, 07:46:52 AM
Regards -- Randy
bax
Randy
I have installed the stereo extension and it's really great. I had to do it myself, since shipping the synth was not an option and Randall was very supportive. Instead of the external mixer box I installed it on the rear panel, which looks great and sounds really cool.
Best,
Steffan
Ncapone
Commerce
Lately I've been inputting it into the Soundforce Chorus 6 module. Even with the chorus mix all the way down you can still have stereo output.
Shaw
Full Member
Quote from: Shaw on September 03, 2025, 04:20:06 AM
— chorus / flanger
— stereo phaser
— micropitch
— slap-back delays
Another trick from the guitar-world (and I'm sure you can find synth examples of this from the 70s and 80s when synths and recording tools were a bit more limited), is to double track mono synths.
— Record a synth track in mono
— record the same track again in mono (a separate performance, not just a copy/paste of the first one)
— pan one left and one right
— the natural variance in performances will create stereo width and interest in the track.
558
Jr. Member
Quote from: 558 on April 30, 2025, 10:26:18 AM
I realized something about this (just yesterday), which is that it's just better to send all the right side eqs straight right only and the left side eqs straight left only.  This is because they all overlap frequencies and sum the frequencies so they may as well not be anywhere in the middle.
558
Jr. Member
Yeah I realized that but I still don't do it though.  There was a recent thing I did that has the 'stereo-ized' sound on it on Rumble:  https://rumble.com/v74u8aw-sequential-circuits-prophet-10-rev-4-synthesizer-asmr.html  The left side has the lows and more highs toward the rights.  but it is a room filled with different frequencies based on my setup thru 10 channels.  It actually seemed to work really well with this arp and more keying.
Analog Prophet
Full Member
Tried the GeForce Prophet-5 demo today. According to Starsky Carr ( https://youtu.be/t4N6aulQTZU?si=McoGdxp3oE5oXp-G ) it's close to identical to the hardware. It has a Voice Spread mode (or Voice Two) that gave me a sense of what a stereoized Prophet-5 Rev4 might sound like. It was interesting...
Full Member
Quote from: Analog Prophet on June 18, 2026, 02:18:54 PM
Starsky does nice comparisons.  I bought the plug-in, it's useful to me in some ways I can't achieve on my P10.  Mostly the fact that I can sketch out sound ideas in my secondary studio with the lovely spartan interface of the P5/10, and when ready reproduce the sound from visual knob positions on the real hardware.
In terms of the sound comparison, I think sometimes comparing analog synths to digital ones using digital measurement tools may not tell the whole story.  I personally find the sound difference to be huge.  There is an aliveness that the hardware has... a punch to the transients, a richness to the harmonics, a feeling of inspiration and wow factor that hardware always seems to have for me that software doesn't.  Do you get the same feeling in side by side comparisons?
I think the plug-in is great and worth the money, and like most software emulations gets you 90% of the way to the same sound.  But man, that last 10%....
Analog Prophet
Full Member
Quote from: LPF83 on June 18, 2026, 06:00:25 PM
Unfortunately I could not make a side by side comparison as my studio is a storage right now due to renovation of the apartment. But I believe I would get the same impression as you.
