Sequencer issue, please help if possible.
« on: November 20, 2020, 06:57:04 AM »
Hello,
After recording a sequence of say GGGG, on playback of pressing the same G note in normal, gated or trigger mode, the note that the audio of the synth is playing is a tone down and sounds F. This happens on every patch and even just using one oscillator. Does anyone else get this behaviour? Is it a known bug or is it bust?
Re: Sequencer issue, please help if possible.
« Reply #1 on: November 20, 2020, 09:40:33 AM »
The sequencer plays back based on a C tonic note.   If you want the sequencer to play in the same key you recorded in, first analyze your recorded sequence to determine the tonic.  In your case, G is your tonic.  G is 7 semitones above C.
Hold down track select, and turn the second soft knob above the screen to turn your G notes into C... ie: Turn it back 7 steps.    Now if you look at your sequence, all your Gs will be Cs - and you can play any keyboard note in Gated mode, and it will play your sequence based on that tonic note.   ie:  if you play the G note, it will play back like you intend.
The alternative to this is just to record your sequences with C as the tonic.   But it's pretty quick to just adjust things after using the method above.
Sequential Pro 3 and Rev 2 - Sound Sets, Patch Banks - Available on Sellfy: https://sellfy.com/sounddesign/  HOLIDAY SALE $10off
« Reply #2 on: November 20, 2020, 04:57:58 PM »
Thank you! That's great. Thank you for the explanation. It is the first sequencer I've owned that acts this way.
