WAV2Evolver
I would like to all add an interesting feeling. Using Wav2Evolver I ended up with "one cycle" instead of 16. However, an interesting phenomenon happened with this single cycle of wave. I don't know if it's due to Wav2Evolver or to the synthesizer but it's very interesting.
With the "single cycle" wavetable generated by Wav2Evolver, when using the Cutoff a filter "self-oscillation" phenomenon occurs. Phenomenon which I find is really interesting, and depending on the pitch of the note, "auto-oscillation" is slower and more progressive.
"It's a unique cycle" but not only, "a kind of hybrid".
I subsequently with a normally generated wavetable, tried to achieve the same effect but without much result. The phenomenon did not happen again.
So interesting, isn't it?
In the immediate future, I will "patch" 2 or 3 wavetables with the Wav2Evolver to have this effect on hand.
If you have explanatory feedback on the circumstances of the phenomenon, I am interested. I will occasionally try to make an audio extract so that we can distinguish the sound result of this phenomenon.
The fact that the filter wobbles is really interesting. it gives an evolving effect of the filter and different sound comes out ... really to hear to appreciate.
___ FR
J'aimerai tous de même ajouter un ressenti intéressant. En utilisant Wav2Evolver, je me suis retrouvé avec "un seul cycle" au lieu de 16. Cependant, c'est produit un phénomène intéressant avec ce seul cycle d'onde. Je ne sais pas si c'est du à Wav2Evolver ou au synthétiseur mais c'est très intéressant.
Avec la wavetable à "cycle unique" générée par Wav2Evolver, lorsqu'on utilise le Cutoff un phénomène "d'auto-oscciliation" du filtre se produit. Phénomène qui je trouve est vraiment intéressant, et en fonction de la hauteur de note, "l'auto-oscillation " est plus moins rapide et évolutive.
"C'est un cycle unique" mais pas seulement, "un espèce d'hybride".
J'ai par la suite avec une wavetable généré normalement, essayé d'obtenir le même effet mais sans grand résultat. Le phénomène ne s'est pas reproduit.
Donc intéressant non ?
Dans l'immédiat, je vais "patcher" 2 ou 3 wavetables avec le Wav2Evolver pour avoir cet effet sous la main.
Si vous avez des retours explicatifs sur les circonstances du phénomène, je suis preneur. J'essayerai à l'occasion de faire un extrait audio pour qu'on puisse distinguer le résultat sonore de ce phénomène.
Le fait que le filtre entre en oscillation est vraiment intéressant. ça donne un effet évolutif du filtre et différente sonorité en ressorte... vraiment à entendre pour apprécier.
