[Solved] Pro 3 SE is bricked since updating?
  • 1812
[Solved] BETA 1.1.2.4 Bricked Pro 3 SE
« Reply #20 on: March 02, 2021, 08:10:59 AM »
I presume you’ve all reported this via a ticket to support so that they address it quickly.
I put in a ticket last night at 10pm Eastern Time USA. They haven't responded yet, but they probably have their hands full with this thing.
« Last Edit: March 17, 2021, 05:57:21 PM by extempo »
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
Re: BETA 1.1.2.4 Bricked Pro 3 SE
« Reply #21 on: March 02, 2021, 08:15:23 AM »
I'm sorry for the trouble. I pulled the update until we figure out what's causing this. Please email technical support in the mean time for help recovering your unit.
SEQUENTIAL
« Reply #22 on: March 02, 2021, 11:35:34 AM »
very same issue here, but I was able to revert back to 1.1.0.0 with the bootloader.
« Reply #23 on: March 09, 2021, 10:12:30 PM »
Can someone please tell me how to use the bootloader to reinstall v1.1? I just ran the beta update because support had sent me a copy of the file (for some reason they didn't think to notify me that it has since been pulled for this issue...).
Do you need to connect via MIDI rather than USB?
« Reply #24 on: March 09, 2021, 11:43:05 PM »
Yes, you need to use the MIDI 5-pin DIN port when using the bootloader mode. Some basic info on using the bootloader mode is here:
https://forum.sequential.com/index.php/topic,4550.msg45765.html#msg45765
As I recall, after the the slider lights have lit up then cycled off, the Transpose 0 light should be blinking to inidicate that the update as finished (at least from past observation).
Hope that helps.
« Reply #25 on: March 17, 2021, 05:53:48 PM »
The update issue has been resolved, and 1.1.2.5 is now available: https://forum.sequential.com/index.php/topic,5201.new.html#new
SEQUENTIAL
