« Reply #2 on: November 13, 2020, 04:43:34 PM »
...when I go to a new mod slot, hold the "source" button, and the press then "noise" button it doesn't work.
Why is this the case?
I'm assuming that when you say 'press then "noise" button', you mean 'turn the "noise" knob'.
I doubt there's a technical limitation. It might be programmed that way because the noise signal used as a mod source is not being derived from the noise that's present in the oscillator section.
I don't think its a limitation, just a bug. Noise can be assigned as a mod source in the matrix and manipulated with the knob for same effect, it's just that holding source doesn't seem to map to it (i.e. the functionality is there, but the shortcut the synth UI offers needs a fix).
