The touch sliders, wheels, and filters are calibrated at the factory and should usually not require re-calibration. However, any kind of calibration won't harm your Pro 2, so you can do it anytime. You'll find the necessary commands in the global settings. There you can choose to calibrate the touch sliders and wheels as well as to autotune the filters. Simply select the desired command after scrolling through the available options in the according menu and follow the onscreen instructions.
