Do i need a audio interface whit midi?
« on: October 30, 2020, 01:12:40 AM »
Hi i've jus bought a P-6 and i'm not shure if i need a new audio interfase whit midiconnection to make it work in logic pro x?
Can i just use the usb and use the P-6 as a softwareinstrument in Logic?
As you can see i'm new to this,thankful for every help!
Re: Do i need a audio interface whit midi?
« Reply #1 on: October 30, 2020, 09:06:32 AM »
You will need an audio interface to be able to record the audio from the Prophet 6. You can send/receive midi using only the USB cable plugged directly into the computer (assuming it has the correct drivers), but that effectively limits the Prophet to being a midi controller keyboard.
« Reply #2 on: November 04, 2020, 10:36:01 PM »
If I understand your question correctly - you can buy an audio interface that does not have its own MIDI ports and simply use a USB port on your PC to receive the MIDI signals via the P6’s USB output.
