How do you get back to the Presets screen without changing the preset.
Please be kind. I have searched through the manual and this forum and am unable to find a solution.
After you make any sort of change to a preset, or move a knob or button etc., which obviously takes you away from the Bank and program screen, I cannot find a method of returning to the preset screen without using the dedicated knobs/buttons that select those.
The problem with this is, that immediately changes the preset.
Please point me in the right direction, or put my mind at ease.
Re: How do you get back to the Presets screen without changing the preset.
« Reply #1 on: October 23, 2020, 09:44:35 AM »
When I've needed to get back to the program info, I've used the Show button, and then turned the program knob.
Not 100% sure if that is a workable solution for what you're looking for.
It sounds like you may be wanting what the Show button does itself. You enable it, then use any button/knob to look at any parameter without changing it. You can also hold the Show button then twist a knob to jump to that screen without changing the value.
Best regards,
Gino
« Last Edit: October 23, 2020, 09:50:27 AM by Gino.Cortesi »
« Reply #2 on: October 23, 2020, 05:49:15 PM »
Thank you Gino,
Yes that does do the job, though it is a little clunky. Strange that a dedicated 'program' button hasn't made it to the panel.
I appreciate your response.
Regards
Steve
