Is there a way...?
korfu
Is there a way...?
« on: October 17, 2020, 12:23:53 PM »
I am hoping there is a way for the arp to follow an incoming midi clock that doesn’t require exact key presses. I can clock an arp no problem from the start, but as soon as I use the keyboard to transpose I need to be extremely accurate or it falls out of sync (though at the same tempo, of course). Is there a way to ensure the arp snaps to a note?
rb415
Re: Is there a way...?
« Reply #1 on: October 17, 2020, 02:25:01 PM »
That sounds like something that could be affected by Global parameter 16, Arp Beat Sync. I have actually not tested both options here with an incoming MIDI clock, but 'Quantize' does do what I think you want when using the internal clock.
« Reply #2 on: October 17, 2020, 03:45:48 PM »
Yup, Quantize locks it to the next beat.
Off is fun for doing things like having an arp on the upbeat.
korfu
« Reply #3 on: October 18, 2020, 01:28:27 PM »
Thanks! I figured I just didn’t have my globals set correctly. I’ll give it a shot.
korfu
« Reply #4 on: October 31, 2020, 08:18:30 AM »
So my patch was set to Global 16 off, but now that I have it on Quantize there is still no sync happening. Are there any other parameters I need to have in play?
<Edit>
Sorry, what I meant to say is that the SEQUENCE does not sync to incoming clock when you start transposing via keyboard. Is this not possible on the Pro-3?
« Last Edit: October 31, 2020, 08:23:42 AM by korfu »
« Reply #5 on: October 31, 2020, 09:23:46 AM »
<Edit>
Are you sure it’s getting the MIDI clock? Check MIDI clock mode, channel, and clock cable in settings.
korfu
« Reply #6 on: October 31, 2020, 11:49:22 AM »
<Edit>
Thanks for the reply! Yes, it’s def getting clock. When the sequence starts it is totally lock step and if I don’t transpose it stays that way. It’s only when I transpose via keyboard that it can fall off if I’m not on beat. I’ve filed a ticket to see if support can help out.
