USB Midi to Midi Thru?
« on: October 08, 2020, 02:43:55 PM »
Does anyone know if you can route USB Midi to the PRO3, and get it to go the regular Midi Thru port?
I'm trying to get midi to a device after the Pro3.
Best regards,
Gino
« Last Edit: October 08, 2020, 03:25:30 PM by Gino.Cortesi »
Re: USB Midi to Midi Thru?
« Reply #1 on: November 08, 2020, 10:30:27 AM »
Best regards,
Gino
I routinely have my set up this way.  Note I exclusively use 5 pin midi DIN cables.  My only real purpose is to redistribute midi clock, so some of your settings may differ there.  Play around with Global>Midi tab>item 5 and try CC or NRPN.  Item 8, turn on MIDI Sysex Enable.
This sounds like an easy fix, you may have already got it working.  Best of luck!
Eric
Pym
  • 201
« Reply #2 on: November 08, 2020, 11:26:32 AM »
No, only clock. There is no MIDI merger inside the Pro3 for USB
Best regards,
Gino
Sequential
