Analog / Digital Purists?
A Thousand Eyes
Re: Analog / Digital Purists?
« Reply #120 on: November 25, 2020, 03:33:00 PM »
I've got everything I need covered with this setup, except I could use a drum machine with extensive external polyphonic sequencing options. I've always went for coolness over functionality with my drum machines/groove boxes, but I probably should resist this urge moving forward... An intuitive UI should be key this time around.
Went with the MPC One as it does everything I need and is certainly the most bang for the buck.
Shaw
  • 1185
« Reply #121 on: November 28, 2020, 04:42:04 PM »
Here's another Prophet 5 mono vs stereo recording.  This time th eProphet 5 is sitting in a (as of yet unfinished) mix with drums and bass (a guitar solo in this section will be forthcoming)...
Anyway, like last time, same preset, slight (very slight this time) variations to the filter, filter envelope, and LFO... then hard panned left and right.  Also with the mono version, also the synth parts are again gain matched.
http://modulatable.com/files/P5_7mix_mono.mp3
http://modulatable.com/files/P5_7mix_stereo.mp3
