I'm having problems using my OB-6 with an iConnectivity MIDI4+. When connected to the MIDI4+ USB host port (via a powered USB hub) the connection is unstable and keeps cycling between showing DSI OB-6 (port 0), then no connection, then DSI OB-6 (port 1), then no connection, and then round again (this is looking at connected devices in Auracle X).
Several other devices on the hub have totally stable connections - e.g. Karp Odyssey, MIDI fighter twister. Have tried different ports and USB cables, having only the OB on the hub, etc. but no stable connection is ever achieved. The OB is fine when connected directly to the Mac, but for my set up I need it on the MIDI4+ hub.
Running 1.5.5 firmware on OB-6, latest firmware on MIDI4+ and Auracle X 1.8 on Mac OS Mojave. iConnectivity website says that OB-6 should be compatible with its USB host port.
Anyone had similar problems or can suggest solutions?
Thanks.
