Adding some more thoughts on workflow. I'll mention that my profession is UX, but I'm here as a musician.
"workflow" is a fairly overloaded term because it does not specify the scope. For example, workflow to create a bass patch on the PRO3. Workflow to create a song using a DAW with the PRO3. Workflow for setting up a jam session with 4 people in the same room (remember those days!). Workflow for creating a musical instrument for production. You get the idea...
So my main question would be: Workflow for what? (The usual When&Where, Who, What&How)
If this were a usability lab, before we observed people trying to accomplish something, we'd need recruit the right representative users, and tell them in general what we want them to try to do (without instructions, as usability is all about observing what people try to do - it's not training and closer to the opposite). My idea here is if we had a scenario Sequential wants feedback on, we could give more targeted feedback.
Open ended questions like "Is there anything that delights or annoys you?" go really well with a lab protocol as probe questions.
With all that said, I want to frame my input to see if it helps.
When&Where: After work, at home in my make shift "music studio" (see pic)
Who: 50 something amateur musician
What&How: Need to make a few catchy riff ideas for a new track, and I'm working with another musician on it. I need to create several of these, and upload the audio clips to our shared Google Drive. I want to leverage the PRO3 for this, and have 2 days to do it.
Plug in cables to my Macbook Pro, and power on my equipment
Start Bitwig Studio (which starts with a blank template)
On the Digitakt (DT for short) set the program to the next blank user one for the PRO3
- On the DT the encoder scrolls through the programs too fast, need to write Elektron about it.
- I do this because I've lost programs I'm editing many times, as a program change just jumps to the next patch
- I've also lost work because I thought increment and decrement were for values in the mod matrix, and not for program changes. Lesson learned.
On the PRO3 init the program and enter a name
+ Like the shortcut down+latch to do this
- Clearing the name should be easier and takes 13 clicks
- Enter in GC## where ## is the program number. Entering numbers takes longer, love the idea of using the keyboard notes to jump to values.
+ I like being able to see the program number when saving, as I use it to increment my patches. I go back and rename
programs GC15 ---to---> Snth-6-Bass when I use it on a real track. Snth is our band name, and we number our
songs to keep track of resources.
Make a unique rhythm on the DT. I typically use the init program on the PRO3 to do this, and lower the octave and the filter just to sketch things. I play on the Argon8 which goes through the DT and it's my main midi controller.
- I record on the DT sequencer because it's my main sequencer, but also the PRO3 sequencer does not have real time recording. That makes it hard to do off beat rhythms.
+ I really like gating the PRO3 sequencer from the DT, that's important as you can quickly mute tracks on the DT and it works with the PRO3 sequencer.
Once I have a rhythm sequence I like, start shaping the voice/program on the PRO3. I'll do a bass program for this one.
In this case I turn all 3 OSCs to the lowest octave, then move the filter to 10 o'clock, add some filter envelope while tapping a note. I then mix the OSCs, and mess with the shape, and shape-mods for OSC1 and OSC2. I typically use OSC3 as a sine sub osc. Once I get something decent, I press write twice.
- I wish we could set what program is used for the init program. As I want OSC3 to default to sine, and I tend to clear the sequencer by recording 1 note (because the default sequencer pattern is cheesy, and it annoys me when I hear it
+ I love the sound of the VCO's, and the filter. I can make interesting bass patches that i like very quickly.
+ I use Compare while the sequencer is running to see if I like my edits. Very cool that you can even load a different program with Compare, and still go back to the patch you are editing.
Now it's time to record the idea to audio.
Add basic drums on the DT if needed.
Record in Bitwig (arm the DT audio track, press play).
While recoding, mess with real-time controls on the PRO3 (filter, effects mix, etc).
After a few minutes of messing around, listen to it, choose the best parts (to get it down to around 30 seconds of audio).
Export as a WAV to Google Drive
I repeat most of those steps above until I have several audio clips posted. Sometimes this is over a few days. When ready I then send an e-mail to the other musician with links to the clips to see what they think (meanwhile they are doing the same, and sending me clips to check out).
This is when we are writing ideas for a new track, it changes when we go to the next phase which is making what we call a "skeleton track" which is just the structure of the song at full length with very basic voices.
You can check out one of our finished tracks here:
https://www.youtube.com/watch?v=7ISnH0Q4HGUBest regards,
Gino
