I do like the concept of eg. a SUB37 where you do have at least some indication about knobs-settings and its corresponding values (envelopes, lfo, etc.)
With the Prophet-6 all knobs have the same scales without any values - so you have 100% to rely "on your ears". Even with the Editor you only get values from 0-127 which do not mean a lot...
So I spent some time to "measure" the most important parameters - youŽll find the outcome in attached .pdf-file.
Pls note:
- These numbers have not been checked by somebody else, it would be great if somebody (DSI??) could confirm them
- I do have very limited testing- und measuring-devices, so the numbers provided are only indications (even if they are with many decimals - they could be wrong)
