« Reply #200 on: June 08, 2025, 11:29:30 AM »
What reason is there to disable certain controllers when in the system menu?
I don't care about the synth controls that much, but could the octave shift buttons and wheels be working normally please?
I would like to use PRO 3 to regularly play other synths as well, which is best done by being in the MIDI system menu, so that I can change MIDI channel to the target synth. However it's a PITA that I must exist the menu if I need to shift keyboard octave.
« Reply #201 on: July 23, 2025, 01:56:32 PM »
While previously recorded notes are being played back, I would like to be able to record parameters using the touch slider.
To do this, I would like to select the track to be recorded and rhythmically play the parameter (e.g., cutoff) while holding down the record button.
« Reply #202 on: August 03, 2025, 09:27:54 AM »
A global setting / preference to require the push of a button before loading a program.
It is SUPER FRUSTRATING that hours of work fine-tuning a new sound can be lost as soon as the knobs for Bank or Program are accidentally touched.
And even in normal use it feels a bit jarring to see the synth trying to respond and load every single program from 1 through 128 when I am scrolling quickly to reach the one I wanted.
It is not a setting I would want to have by default: normally I like instant load – but it is way too easy to load a program while trying to turn another knob on the front panel. PLEASE.
« Reply #203 on: August 11, 2025, 11:50:34 AM »
ADJUSTMENTS:
- Merge FX1 + FX2 type & amount pages together onto a single page. Then following is already present behavior - Pressing SHOW EFFECTS shows this new merged page. Pressing SHOW EFFECTS + EFFECT 1 opens Effect 1 Params menu, similarly for effect 2.
Additionally, Effect 1/2 buttons should only on/off effects and NOT change display. So that is is possible to use them as performance buttons, while simultaneously adjusting effect parameters / amounts.
« Reply #204 on: August 12, 2025, 10:35:09 AM »
Great suggestions, please send these to support@sequential.com, they are more likely to be implemented by emailing support.
« Reply #205 on: August 12, 2025, 10:35:46 AM »
« Reply #206 on: December 28, 2025, 11:15:42 AM »
Any chance we’ll see the new arp modes from the latest TEO/Take 5 firmware ported over to the Pro 3 (and Rev2 and 6-series)?
Logic Pro | Pro Tools | OB-X8 | Prophet 6 |  Trigon 6 | Rev2 | Pro 3 | SE-1X | Artemis | UDO Super 6 | Integra-7 | TR-1000 | TD-3 MO | TD-3 | Maschine+
« Reply #207 on: June 02, 2026, 09:48:21 PM »
Would still love to see portamento/glide added to the sequencer.
Please.
« Reply #208 on: September 14, 2026, 03:39:05 AM »
Where is the latest Pro3 firmeware ? Because it is not at the provided link, dexcribtion but not the firmeware file itself
https://sequential.com/updating-the-pro-3-os/
Pro 3 SE #295
macOS, Logic X, Eurorack
https://www.youtube.com/user/daSunBrain
« Reply #209 on: September 14, 2026, 01:16:44 PM »
You can get there by clicking Support --> Pro 3 --> Operating System.
https://sequential.com/support/download/pro-3-operating-system/
