MIDI Out Issue Since 1.1 Update
« on: August 26, 2020, 05:55:24 AM »
I've been having weird issues with the sequencer/arp when the MIDI Out Select is set to anything other than MIDI 1, such as USB.  When a sequence/arp is running, if I attempt to use the keyboard to transpose to other notes, the notes seem to choke each other out and I get nothing.  I have to completely lift off of the previous note before I can play another one.  So, there's no way to play fluidly.  When I switch the MIDI Out Select back to MIDI 1, everything becomes normal again.  Of course, this means I have no MIDI to my DAW now.
S Y Z Y G Y X
  • 162
  • WWW.SYZYGYXMUSIC.COM
    • S Y Z Y G Y X
Re: MIDI Out Issue Since 1.1 Update
« Reply #1 on: August 26, 2020, 08:42:09 AM »
Sounds like a midi feedback loop, what DAW are you using?
The same thing happens on my Pro 3 when the R red record button is enabled on the track.
www.syzygyxmusic.com
https://syzygy-x.bandcamp.com
« Reply #2 on: August 26, 2020, 08:25:35 PM »
I'm using Ableton, but this occurs when I have nothing but headphones plugged into the synth.  I basically have no MIDI out, at this point.  Even the editor can't communicate with the synth.  Personally, I wouldn't mind reverting back to the original firmware.  It seemed that everything was working fine before the update.
