Hello, are the audio outs balanced or unbalanced?. Should I be using TRS or TS?
11. Audio In—Unbalanced, 1⁄4 inch audio input. The Pro 3 accepts exter- nal audio signals for processing through this connector. Input level can be adjusted using the ext audio knob in the Mixer section.12. Audio Outputs—Unbalanced, 1⁄4 inch audio outputs. The Pro 3 sounds great in stereo, but can be switched to mono if needed. See “Global Settings” on page 96.
