Program Display Choice - Power On?
« on: August 16, 2020, 06:48:46 PM »
Hi everyone☺
I'm writing to ask,  is there a way to have the "last program used" to be available when you turn the Pro2 on?
Each time I power on, regardless of what program I last used, it always reverts F2 P34.  Do I have some choices for the Pro 2 state when powering up?
Thanks in advance. ...
jg666
  • 542
Re: Program Display Choice - Power On?
« Reply #1 on: August 17, 2020, 05:25:03 AM »
If you press the Globals button and then press again to come out of the globals, then turn off the synth and back on again, it will load the patch that was loaded when you pressed globals.
So the basic rule is that it will start up on the last patch where globals was pressed before powering down and then continue to start up on that.
Hope that makes sense? It’s much easier to do than to describe :)
« Reply #2 on: August 17, 2020, 02:36:47 PM »
Very good - I understand totally.
I knew I had done something to change the start-up patch, but I could not tell what it was!
This synth is new to me, so my first week is just exploring presets.   Wow! ☺
Thank you for the clear reply....☺
jg666
  • 542
« Reply #3 on: August 17, 2020, 02:41:08 PM »
You’re welcome, hope you have many a happy hour with your Pro2 :)
